Odd T differential spider
Kenny Edmondson
Topic author - Posts: 162
- First Name: Kenny
- Last Name: Edmondson
- * REQUIRED* Type and Year of Model Ts owned: 1923 Touring 1924 Roadster PU
What is this T style differential spider for? No center hole for the axles…
- Attachments
- IMG_0002.jpeg (36.19 KiB) Viewed 1408 times
RVA23T
- Last Name: C
Re: Odd T differential spider
Man I wish it was April 1 so I could say
"Japanese export differential with extra Ninja throwing star included."
Fonzie says AAAAAAAAAAAAAA
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Perhaps a really early spyder? Kim Dobbins may know. Any chance it has DB on it. I know the really early spyder gears had bronze bushings in them.
Kenny Edmondson
- First Name: Kenny
Well it is a Model A spider. Never would have guessed that. Same exact size as a T only no hole… Thanks John.
RVA23T
- Last Name: C
so the A axles are retained by the carrier correct?
And Model A spider gears are the same as T. Later they did add an oil hole, but fit and function, the same. Take some time to go through the 1928 Model T parts book, you will find a few parts that carry the A part numbers.
