What is this at the base of a wood utility pole?
ivaldes1
First Name: Ignacio
Last Name: Valdes
Post by ivaldes1 » Mon Mar 18, 2024 8:07 pm
What is this little metal circular threaded thing with a star shaped top embedded at the base of a wooden utility pole for?
Re: What is this at the base of a wood utility pole?
Post by Norman Kling » Mon Mar 18, 2024 8:13 pm
It might be a core plug. When a pole is getting older the utility company will drill a small hole to check for rot at the center of the pole to decide whether the pole needs to be replaced. Then they put a plug in the hole to keep water and bugs out.
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Post by Herb Iffrig » Mon Mar 18, 2024 8:38 pm
I think you are right Norman.
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Tue Mar 19, 2024 4:13 pm
They have gotten so bad about doing that around here i hope they are putting some glue around the plug or the poles are going to fall down from all the drilled holes.
Duey_C
First Name: Duane
Last Name: Cooley
Post by Duey_C » Wed Mar 20, 2024 1:35 am
Insect (ant) repellent. How that screw delivers it is unknown to me.
Called our local guys about an ant hill next to our pole as the pole was starting to move.
They nudged it back some, re-tamped the dirt and put the screw in the pole. Boom done.
