Morning from snowy Vermont, I need to repair a broken piece of bakelite from the bottom of my coil box switch base. I am wonder what would be the best adhesive would be to use.
Fitz
bakelite repair
Herb Iffrig
- First Name: Herb
- Last Name: Iffrig
Re: bakelite repair
One time I repaired a Bakelite knob and used Kwik poly. I used a black powder to tint it to match. It turned out pretty well. I used sandpaper and a file to finish shape it.
jiminbartow
- Last Name: Patrick
Re: bakelite repair
Hello from sunny Florida. 5 minute clear 2 part (mixed 1:1) epoxy that comes in a 2 cylinder syringe. Get it at Lowe’s or Home Depot. Read the label and get the one that is rated for the greatest strength in Lbs. I believe some go as high as 5,000 lbs. Jim Patrick
Re: bakelite repair
Looks like an epoxy will work (Kwick Poly is no longer made) https://www.google.com/search?client=fi ... ir+baklite
So look for one that sets up black to match.
JB Weld & Gorilla Glue also have been used see internet link
Re: bakelite repair
I have used Bondo to repair or replace bakelite with good results:
https://www.mtfca.com/phpBB3/viewtopic. ... ing#p28584
https://www.mtfca.com/phpBB3/viewtopic. ... ting#p6915
hah
- Last Name: hardiman
- * REQUIRED* Type and Year of Model Ts owned: 26 coupe
Re: bakelite repair
As he says, bondo! If it’s a significant piece use mar-glass.
