Dome light switch WTB
EricMac
Topic author - Posts: 349
- First Name: Eric
- Last Name: Macleod
- * REQUIRED* Type and Year of Model Ts owned: 13 Touring, 26 Touring (2006 Stynoski), 27 Fordor, '92 Stynoski, 'owner emeritus
Mayhap I am dreaming but I'm looking for the last little detail I need for my '26 Fordor restoration, the elusive dome light switch. If you happen to have one please let me know. It looks like the photo I copied from this forum.
Thanks so much.
1913 Touring
1926 Touring (2006 Stynoski)
1927 Fordor
1926 Depot Hack project
1927 Fordor
Kenny Edmondson
- First Name: Kenny
- Last Name: Edmondson
- * REQUIRED* Type and Year of Model Ts owned: 1923 Touring 1924 Roadster PU
Re: Dome light switch WTB
Hard to tell exactly from the pictures, but do the pictures below look anything like the switch you’re looking for? If the bezel is separate, I don’t have it. If there is no bezel then this probably isn’t correct…
- Attachments
- IMG_0049.jpeg (21.07 KiB) Viewed 1484 times
- IMG_0047.jpeg (19.86 KiB) Viewed 1484 times
Yours is a 1915 Push/Pull Headlight switchKenny Edmondson wrote: ↑Wed Mar 27, 2024 1:50 pmHard to tell exactly from the pictures, but do the pictures below look anything like the switch you’re looking for? If the bezel is separate, I don’t have it. If there is no bezel then this probably isn’t correct…
- Attachments
- Brass 5.jpg (69.35 KiB) Viewed 1475 times
- versions.jpg (25.6 KiB) Viewed 1475 times
- SW 4.png (129.48 KiB) Viewed 1475 times
EricMac
- First Name: Eric
Thanks for looking and offering this up. No. It does not look like the right part...but I wish it was.
1913 Touring
1927 Fordor
1927 Fordor
EricMac
- First Name: Eric
I stumbled across this while looking for another part for a front end. The correct part is officially found. I thought I would post this so if others are restoring a '26-27 Fordor they know what they are looking for.
1913 Touring
1927 Fordor
1927 Fordor
Joe Bell
- First Name: Joe
- Last Name: Bell
eric that is the one I have in mine!
Kenny Edmondson
- First Name: Kenny
Joe, thanks for the information and Eric, thanks for the correct pictures.
