Bronze Thrust Washers
GeorgeHounslow
Last Name: Hounslow
* REQUIRED* Type and Year of Model Ts owned: 1915 Speedster 1916 Tourer
Post by GeorgeHounslow » Sun Mar 24, 2024 4:20 pm
Hi All,
Another question if I may, I had the back axle apart last winter (2022/23) as I wanted to check the thrust washers had been replaced with bronze ones, which they had, there didn't appear very much side to side movement of the back wheels/half shafts/diff assembly at that time but today I checked and there does seem to be some, I wondered if you would know as to the cause of this as it seems quite a rapid change? And as they are bronze is it ok to keep using the car for the time being ( I have rocky mountain brakes)?
Many Thanks
George
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Re: Bronze Thrust Washers
Post by Rich P. Bingham » Sun Mar 24, 2024 5:26 pm
Some gear oils are not compatible with bronze parts.
How much “slop” are we talking over how many miles ?
Get a horse !
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Sun Mar 24, 2024 5:27 pm
Get a horse !
Post by Jerry VanOoteghem » Sun Mar 24, 2024 6:54 pm
When the rear end was assembled, was there the fiber washer/spacer between the two axles? I've never taken a rear end apart where the fiber washer still existed. If it was fiber, it may have been ground away, allowing some side-to-side movement of the axles. If that's the case, it's not a big deal.
Post by Allan » Sun Mar 24, 2024 7:39 pm
I use one of our brass $1 coins to replace the fibre washer between the axles. They are thick enough that they can be sanded down to make a custom fit for the particular job. A collapsed bronze diff thrust may allow the crown wheel and pinion gear to over-ride one another. Hence the safety compromise, because you will lose the Ford transmission brake.
A collapsed fibre washer will not have the same effect. It will upset the meshing of the axle and spider gears, probably making more noise.
Post by Wayne Sheldon » Sun Mar 24, 2024 10:12 pm
Allan, I have used an American quarter dollar for those! The fit is near perfect, their copper/nickel composition is much more durable than the original fiber disc, and they are cheaper than the "proper" replacements!
