WTB 19-20 ignition switch
Model T Mark
Last Name: Eyre
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring 1914 Touring and Roadster 1915 Touring 1926 Roadster
Post by Model T Mark » Mon Mar 25, 2024 8:39 pm
I’m looking for a really good or perhaps a new old stock ignition switch with the heavy cast light switch handle. We are struggling with broken pot metal parts. This is the last part needed to complete the restoration of a high point show car. It’s a Canadian export to Australia. Any help would be greatly appreciated. Thanks in advance. Mark Eyre/Ralph Boyer. Contact me through this website.
Karl Von Neumann
First Name: Karl
Last Name: VonNeumann
Board Member Since: 2022
Re: WTB 19-20 ignition switch
Post by Karl Von Neumann » Wed Apr 10, 2024 3:33 pm
Is this the switch handle ?
Model T Mark
Last Name: Eyre
Post by Model T Mark » Wed Apr 10, 2024 4:00 pm
I really need the contacts on the back side that are good enough to use. It the right switch Handel though.
Post by TRDxB2 » Wed Apr 10, 2024 4:53 pm
You need to show the parts you need. There were many manufacturers & even variations by them. I have some parts for the odd ones. The four rivets on the face of the switch points to a "Clum" manufactured switch (but could be another as well). There are a few different versions of the parts used for Clum & the repro parts don't work on them. So....
These are two different "Clum" switches for Model T's & neither yours with a cast handle
Lots of possible switch plates - not all Ford
My guess is that you want to have one like this
This shows two different cast handles
Model T Mark
Last Name: Eyre
Post by Model T Mark » Wed Apr 10, 2024 8:46 pm
I’ll take it apart and get some pictures. I knew there were several and the one I’m looking for is the one that has the large plate secured by two acres at the bottom that attaches it to the plate. Ours is so warped it doesn’t make good contact with the dim side. I have filed it flat and can’t do anything more to make it useful.
Karl Von Neumann
First Name: Karl
Post by Karl Von Neumann » Thu Apr 11, 2024 10:19 am
Mark ill pull this one out of the dash and see what it looks like it does move and snap into place real well
Karl Von Neumann
First Name: Karl
Post by Karl Von Neumann » Mon Apr 29, 2024 3:30 pm
I stumbled across another light switch mark if you still need one
