Horn Kit
Model T Matt
Topic author - Posts: 531
- First Name: Matt
- Last Name: Madison
- * REQUIRED* Type and Year of Model Ts owned: 1923
Horn Kit
2 ft Horn kit new in box part T-13802-HS2 asking $80.00 includes shipping call Matt 503-82four-268one
Model T Matt
- First Name: Matt
Re: Horn Kit
Held for John
Rick_Rice
- First Name: Rick
- Last Name: Rice
- * REQUIRED* Type and Year of Model Ts owned: 1925 TT Closed Cab Express
Re: Horn Kit
Everyone,
I missed out on this kit and need one real bad for my 1914 open express truck. Please, if anyone else has one available or if you can tell me where I can order a new kit, let me know. Thanks in advance for your reply back!
Kind Regards,
Rick Rice
three three 0 seven one 4 eight one 5 one
Kind Regards,
Rick Rice
Model T Matt
- First Name: Matt
Re: Horn Kit
will check inv.today bought out a vendor-stock has been out of circuit around 8 yrs-
Rick_Rice
- First Name: Rick
- Last Name: Rice
Re: Horn Kit
Matt,
Thanks for your response. I did some on line detective work from your photos and found the kits in Ohio! You are right, the old supplier is no longer around, but by chance I found the old car guy who took over and can help us brass car guys out! I spoke directly with the owner, Jim Watt.
Jim informed me he can supply the kit, which is USA sourced and the kit comes in four (4) different lengths of the flexible brass tube, 2', 3', 4' and 5' lengths. The part number for the kit:
T-13802-HS2
-HS3
-HS4
-HS5
I measured my particular application requirement with a string and found that I need about 40" of flexible brass tube length. Per Jim, the flexible brass tube can be easily shortened, as long as you make a straight clean cut with a cut-off wheel, so I purchased the 4' kit. I hope this helps someone else in their search for a complete brass horn installation kit.
Kind Regards,
Rick Rice
CONTACT:
Vintage Part Club
Jim Watt, Owner
20 West George Street
Arcanum, Ohio 45304
(937)692-6100
T-13802-HS2
-HS3
-HS4
-HS5
Kind Regards,
Rick Rice
CONTACT:
Vintage Part Club
Jim Watt, Owner
Arcanum, Ohio 45304
(937)692-6100
Mark Chaffin
- Last Name: Chaffin
Re: Horn Kit
Vintique makes the horn kit. The word is Chad was waiting on getting the horn bulbs back in stock before making more kits. The horn bulbs are now available.
Rick_Rice
- First Name: Rick
- Last Name: Rice
Re: Horn Kit
Good information, thanks Mark! I'm really glad some items are starting to surface and be available again! A guy can order a kit today from Jim (937)692-6100.
