High low gear and spacer
Ericgj85
First Name: Eric
Last Name: Johnson
* REQUIRED* Type and Year of Model Ts owned: 1926 speedster
Post by Ericgj85 » Mon Apr 08, 2024 1:35 pm
I bought this set up from a member on here just to see how it works but have never used them. They are made for Closing up the ratio between low and high keeps the engine in its power band on the shift to high.Two parts are involved, a spacer and a driven gear with 29 teeth and flipping standard triple gears upside down . Along with this a new rear end ratio is a must 9 or 10 tooth pinion should do it . With this set up you loose reverse but it was made for racing purposes where that’s not really an issue I’m asking $300 plus shipping as they cannot be made for less than that. I will attach photos along with one that that was posted showing this set up put together
Richard K
Last Name: Kemp
* REQUIRED* Type and Year of Model Ts owned: 1926 TT Tow Truck
Re: High low gear and spacer
Post by Richard K » Mon Apr 08, 2024 3:56 pm
Email sent for purchase of above item. Thanks Rich
Ericgj85
First Name: Eric
Last Name: Johnson
Post by Ericgj85 » Mon Apr 08, 2024 4:54 pm
Sold , I do have a second set if anyone is interested .
Ericgj85
First Name: Eric
Last Name: Johnson
Post by Ericgj85 » Mon Apr 08, 2024 10:21 pm
Sold second set
