What year loaded Model T
Herb Iffrig
Topic author - Posts: 1768
- First Name: Herb
- Last Name: Iffrig
I thought[ it would be fun to have a discussion on what year this Model T might be.attachment=0]what year T.JPG[/attachment]
- Attachments
- what year T.JPG (45.26 KiB) Viewed 2238 times
- Last Name: Strange
- Board Member Since: 2013
Re: What year loaded Model T
Curved rear fenders, billed front fenders, electric headlights, black & brass side lights - I'll go with 1916.
- Last Name: Wrenn
Sidelights look like have brass rim so I'm saying '15
And the aftermarket accessory K-W Road Smoother shocks don't seem to be able to help the chassis, the rear fender is resting on the tire
- Last Name: Hjortnaes
I count 33, but there might be one hidden in the back that I did not count.
I counted 34. You may missed #6 looks like a big head of hair behind #7. Also #4 is set back then behind #5 & #7
- Attachments
- head count.png (296.28 KiB) Viewed 2060 times
- Last Name: House
I’m with Tim. A 1915 due to the brass headlamp and cowllamp rims.
And some load on that ‘15 too.
Note #16 is likely the dean, big at approx. 200 lbs. #19, the young teacher, prob. 160lbs. Now add up the 32 students, including the little girls on the folded top, using approx. 65lbs. each…….grand total 2,536lbs.
- Last Name: Wrenn
A testimony to the stregnth of the frame!!
Rich P. Bingham
- First Name: Rich
- Last Name: Bingham
I’m a little concerned by the backwards slant of the radiator ! Do you suppose that load of over a ton of humanity has bowed the frame ?
Get a horse !
