Question on the I timer
Will
First Name: Will
Last Name: Copeland
* REQUIRED* Type and Year of Model Ts owned: 1915, 1919, 1923 TT
Post by Will » Fri Apr 12, 2024 5:50 pm
Question, Do you still need to retard the timing lever ATC on the I timer to start the car or does the timer do that on its own? Thank you.
As Tom Sellick told Marston in the movie Quigley Down Under, I told you I dont have much use for handguns, I never said I didn't know how to use them!
Bill Anziani
First Name: Bill
Last Name: Anziani
Re: Question on the I timer
Post by Bill Anziani » Fri Apr 12, 2024 7:46 pm
You need to retard it, just like the original timer.
Last Name: Hjortnaes
Post by DHort » Fri Apr 12, 2024 10:08 pm
Then once it has started you advance it just like any other timer
