Color for coil box wood 1926
TFan
Topic author - Posts: 409
- First Name: Jim
- Last Name: Riedy
Got a new wood kit for my coil box, wondering what if any color it should be or maybe just clear coat with some varnish. I searched the older posts but came up empty. Any suggestions wood be appreciated. (pun intended) JIm
Moxie26
- First Name: Robert
- Last Name: Jablonski
Re: Color for coil box wood 1926
Jim... I have used boiled linseed oil on replacement wood . Gives you nice color to the wood and also seals against moisture and carbon tracking possibilities later on..... One to three coats of oil after a few days to me is fine before assembling into coil box.
- Last Name: Hatch
What happened to the Fun Project replacement?
Need to ask Birdhaven
Tried to colorize an old photo. Didn't change much but looks like unpainted wood. We do know that Henry wouldn't add a process if it was unnecessary and added cost.
Yes sealing is advisable. I use Minwax wood hardner - it penetrates into the wood fibers. Others uses a variety of sealing methods
TFan
- First Name: Jim
- Last Name: Riedy
Thanks for the replies so far, I think the linseed oil sounds the best to me since I have some on hand. As far as the plastic or nylon I'm cheapskate so didn't even ask if it was available. Jim
