Placement of speedometer head
RGould1910
Last Name: Gould
Post by RGould1910 » Mon Apr 15, 2024 4:28 pm
Are there any photos or dimensions telling me where to install the speedometer head on a two piece firewall (early 1912)?
The hole for the cable has already been drilled in the floorboard so that sets the horizontal position. Im looking for info re the vertical placement.
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
* REQUIRED* Type and Year of Model Ts owned: 1911 Torpedo,1913 Touring, 1914 Runabout, 1915 Coupelet, 1916 Coupelet, 1917 Coupelet
Re: Placement of speedometer head
Post by Russ_Furstnow » Mon Apr 15, 2024 4:47 pm
Richjard, Place it so the top of the speedometer head is the same height as the top of the coil box lid. The hole in the floorboard should be directly below the speedometer input shaft. I hope thishelps, Russ Furstnow BTW, your pinion gear is in the mail.
RGould1910
Last Name: Gould
Post by RGould1910 » Mon Apr 15, 2024 5:22 pm
Thanks Russ thats what I needed. Check has been sent.
Jones in Aiken SC
First Name: Gregory
Last Name: Jones
Post by Jones in Aiken SC » Mon Apr 15, 2024 7:04 pm
Russ has already given an answer to your question but I thought this also might be of interest to you. I have this note that the previous owner of my "Late 11/early 12" Commercial Roadster, Ken Jones, made based on an original firewall for the car. My guess is that it corresponds with what Russ says. (I haven't gotten to the point of mounting the speedometer yet to confirm these dimensions)
RGould1910
Last Name: Gould
Post by RGould1910 » Mon Apr 15, 2024 8:29 pm
Thanks Greg. Appreciate your input.
