Starter ring gear
Bruce Compton
First Name: Bruce
Last Name: Compton
* REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
Starter ring gear
Post by Bruce Compton » Thu Apr 18, 2024 8:38 pm
I have a '14 T with a recently rebuilt motor (bought this way) and now I'm thinking of installing a starter. I already have the later (1920) hogshead with lettered pedals and a new starter but I don't know if the motor has the ring gear installed. Is there any way of seeing or feeling to tell if the ring gear is installed without removing the hogshead. Thanks in advance.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: Starter ring gear
Post by Dan McEachern » Thu Apr 18, 2024 9:09 pm
You should be able to remove the inspection plate on the hogshead and look inside and see the outer edge of the flywheel. A ring gear mounts to the rear side of the flywheel and is visible thru the inspection plate.
Post by Norman Kling » Sat Apr 20, 2024 12:53 am
you might need to replace the flywheel. I don't think the older flywheels were machined for a starter ring.
jsaylor
Last Name: Saylor
Post by jsaylor » Sat Apr 20, 2024 7:29 pm
Also, the Mag Coil ring needs a notch on the left side to clear the starter bendix drive. Unless the previous owner was planning on a starter at some time later, more than likely the original flywheel and mag ring was used.
