seeking picture of correct 1911 Torpedo fuel line routing
Post by Scott_Conger » Sun Jun 02, 2019 8:59 pm
I have never seen a diagram or picture of the correct routing. An early post by John Ragan hints at the oddity and discusses the unique shut off valve as well. I would be ever so grateful if someone with a Torpedo could provide a sketch, picture or good verbal description of the line, it's routing, and rotational position of the sediment bulb (I believe the outlet is NOT directly foreward).
I have copies of pictures/diagrams for touring, sedan, coupe, runabout. None of these are correct for a Torpedo.
Thank you in advance for any info you can provide.
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Re: seeking picture of correct 1911 Torpedo fuel line routing
Post by Herb Iffrig » Sun Jun 02, 2019 9:23 pm
Trent Boggess had a diagram on his webpage years ago.
I will see if I can locate that for you or perhaps Trent will chime in here to help.
Herb
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Post by Herb Iffrig » Sun Jun 02, 2019 9:31 pm
I found it bt searching Trent Boggess torpedo roadster.
http://jupiter.plymouth.edu/~trentb/Mod ... 16Y2K.html
Herb
Post by Scott_Conger » Sun Jun 02, 2019 11:06 pm
Herb!
Outstanding!!!
I even have a copy and link to that article and did NOT remember there was fuel routing info.
THANK YOU!!!!
regards, and thanks to MTFCA for the forum
