Only needed 1… wound up making 10!
Set of 3 flanges made from 1/2” thick mild steel and will fit T/S model Fronty heads... maybe others. 2-3/4” bolt centers and 1-5/8” thru. These are laser cut then chamfered in the CNC. 3 sets available - $65 + shipping
Fronty header flanges
Kevin Pharis
Topic author - Posts: 1618
- First Name: Kevin
- Last Name: Pharis
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
Re: Fronty header flanges
Consider em yours Richard! I’ll send an email to work out the details
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
Turns out that a T/S model Fronty head has an exhaust port bolt spacing of 2-11/16”. Holes in the flanges have been reworked, and my dad has been reminded that guessing is not an accurate form of measurement
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Close counts for some stuff... Had the same problem with some carb flanges recently, luckily the boo boo fit other carbs I had. funny how 1/16th makes a difference
