Anyone have any orphan internal switch parts available ? I'm looking for a couple sets of the small (key) & larger (lights) internal pieces. The rear contacts are available new - trying to help a buddy fix his original - it was reconditioned by Ben a while back but he's a bit rough on it ! Drop me a note through the Forum if you can assist - Thanks.
These are what I'm seeking:
Wanted: Ignition Switch Internals
Topic author - Posts: 5611
Re: Wanted: Ignition Switch Internals
BTT - anyone ?
There are differences in these pieces. The pin type are thicker than the clip on. The light ring prongs are also different and need to match the fiber ring.RajoRacer wrote: ↑Fri May 03, 2024 11:31 amAnyone have any orphan internal switch parts available ? I'm looking for a couple sets of the small (key) & larger (lights) internal pieces. The rear contacts are available new - trying to help a buddy fix his original - it was reconditioned by Ben a while back but he's a bit rough on it ! Drop me a note through the Forum if you can assist - Thanks.
Appreciate the info Frank - I'm searching for both types - I traded all my parts to Ben a few years ago - need to put a couple together for myself.
