Model T Emoji for my cell phone?
ivaldes1
Topic author - Posts: 960
- First Name: Ignacio
- Last Name: Valdes
I was asked why I don't have a Model T Emoji for my cell phone? Good question. I looked for one and could not find one. Does it exist for iPhone?
ModelTWoods
- First Name: Terry
- Last Name: Woods
Re: Model T Emoji for my cell phone?
Ignacio, take a picture of your T or your favorite T photo and transfer it to your phone's wallpaper.
signsup
- First Name: Robert
- Last Name: Brough
- * REQUIRED* Type and Year of Model Ts owned: 1915 War Wagon 1927 Depot Hack 1927 TT
If you have a unique horn, you can also record it and use that as your ring tone. I have a WWII jeep "beep/beep" as mine and a lot of people recognize it.
A bunch of old cars
Sometimes they run.
Sometimes, they don't.
A bunch of old cars
Sometimes they run.
ivaldes1
- Last Name: Valdes
So no model T emoji exists? These are the little ones you put in a text message:
ModelTWoods
- First Name: Terry
- Last Name: Woods
Oh, so that is what you were looking for ! I don't think the EMOJI Gods have had a call for that one yet. Unless you can sign up a list of T owners who are as eager to express their feelings with such vigor, you may be in for a wait for such a symbol.
PDGx
- First Name: Paul
- Last Name: Grohsmeyer
Well there is a way to get that done depending on what phone or iPad you have.
Bring up a photo that has not been edited (doesn’t work well if edited) and hold your thumb/finger on your vehicle. If the screen appears to ‘cut out’ the image with a white line, you are in.
You will be given the option on the pop up to ‘copy - add sticker - or share’
Select ‘add sticker’.. You will see it added to your emoji file
You can then use it like an emoji in text messages - but this site……doesn't let you use it.
Try it. It might work on your hardware.
If my short term memory gets any shorter, I won’t even have thought about what I’m going to forget.
17 TT Holmes Wrecker
22 Mack AC Tiltbed Wkr
30 A Rdstr PU
58 Mack B-61 Semi Tractor / 85 Roger’s RGN
08 Philbilt Stepdeck Semi
30 A Rdstr PU
ivaldes1
- Last Name: Valdes
So far the answer is: with difficulty. I created this little .png attached but to get it to display correctly as an emoji on iphone is far more difficult than it should be. If you copy it into a message it scales it up beyond actual size which makes it look blurry. At this point I cannot find a way for it to display actual size. So far there is no easy way that I can find to put it on as an emoji.
-- IV
- Attachments
- tinymodelt.png (684 Bytes) Viewed 2340 times
ivaldes1
- Last Name: Valdes
I hold down on it, it outlines but then it only brings up Copy and Share... no Add Sticker.
PDGx wrote: ↑Sun May 05, 2024 9:51 amWell there is a way to get that done depending on what phone or iPad you have.
ivaldes1
- Last Name: Valdes
I updated to the latest and now I hold down on it and it does nothing.
