What the...?!!
What the...?!!
Post by Steve Jelf » Thu May 09, 2024 1:43 pm
Nothing about how to apply for authorization? :D
Last Name: Wrenn
Re: What the...?!!
Post by TWrenn » Thu May 09, 2024 1:57 pm
Never seen this one before!
mtntee20
First Name: Terry & Sharon
Last Name: Miller
Re: What the...?!!
Post by mtntee20 » Thu May 09, 2024 2:19 pm
Steve, If they are YOUR messages, why does the forum require authorization? I would recommend contacting Admin.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Re: What the...?!!
Post by ThreePedalTapDancer » Thu May 09, 2024 2:43 pm
Delete some of your inbox messages it probably is telling you your inbox is full. If it’s full it won’t allow you to read messages until you make more room by deleting old messages. If full, incoming messages will be “on hold” until you allow more room.
Re: What the...?!!
Post by TRDxB2 » Thu May 09, 2024 4:08 pm
My screens were a bit different, possibly because I had messages
To see and/or delete
Click on PRIVATE MESSAGES
The inbox with message is return if you have any
Check the ones you want action - example Delete Marked
Follow screen instructions from then on
Re: What the...?!!
Post by Steve Jelf » Fri May 10, 2024 1:33 pm
OK, so I managed to find my stored messages. The box was 100% full so I picked a few to delete. Now, there they sit with check marks after them. But I don't find a Delete button anywhere. How can I get rid of the ones I checked?
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Re: What the...?!!
Post by ThreePedalTapDancer » Fri May 10, 2024 2:48 pm
After you select/check messages to delete, go to right side near bottom, push for drop down menu, select “delete marked”
Re: What the...?!!
Post by TRDxB2 » Fri May 10, 2024 4:41 pm
Then click on the GO icon
go do it.png (171.96 KiB) Viewed 1249 times
