FS - Zenith S4BF fuel line adapter
Post by Scott_Conger » Sat May 11, 2024 2:28 pm
this adapts the FORD 1/4" fuel line to the S4BF 5/16" inlet - just found this in stock
I will be making more this summer, but this one is available immediately
High quality, silver soldered connection - no lead solder; no junk
EMAIL FOR INFO
Example of adapter installed - you are not purchasing a carburetor with this part
Re: FS - Zenith S4BF fuel line adapter
Post by Scott_Conger » Sun May 19, 2024 3:30 pm
I thought I remembered someone out there asking about one and when I was going to make more (?)
If this doesn't go fairly soon, there sure won't be any more for a long time...no point investing time and materials into things that no one wants or needs.
Full Flow Float Valves keep me busy enough!
tom leroux
First Name: TOM
Last Name: LEROUX
* REQUIRED* Type and Year of Model Ts owned: 1915 speedster-1927 pick up
Board Member Since: 2006
Post by tom leroux » Wed Oct 16, 2024 2:41 pm
Scott
will take two when you make them
thanks tom leroux
tom leroux
First Name: TOM
Last Name: LEROUX
Post by tom leroux » Wed Oct 16, 2024 10:03 pm
scott
I will take the one you have
tom leroux
