Ruckstell axle end play.
model t mike
Topic author - Posts: 10
- First Name: michael
- Last Name: hewittt
Setting the axle side play on a Ruckstell per the MTFCA manual. One bronze washer is not thick enough, a bronze washer and fiber washer is too thick. I have been sanding both washers, but that is a tedious task. Are washers available of different thickness? The manual says to sand two fiber washers. Any problem with using a bronze and fiber washer together?
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Re: Ruckstell axle end play.
If you are referring to the fiber washer inside the planetary assembly, there should only be enough space for a single fiber washer. As a sanity check, substitute a steel thrust washer and see how much side play you have. Something is wrong if you have excessive side play with a single steel washer installed. You should have about .010 side play if everything is as it should be. Post some pictures of your setup and we can go from there.
RGould1910
- Last Name: Gould
The parts suppliers make shims.
Mike, call me or see me @ the meeting tonight.
If you are @ Toms right now, feel free to see me.
Not clear which of the 3 possible areas you have issue with.
model t mike
John, working now. Will see you at the meeting tonight. Thanks all.
