One bushing in brake drum???
Last Name: Hatch
Post by Dan Hatch » Tue May 14, 2024 3:54 pm
Does anyone have a copy of Service Bulletins where it has to only install one bushing in brake drum. I am away from my Bulletins and someone ask me about that. Think it was late 25. Can you please post it here? Thanks Dan
Re: One bushing in brake drum???
Post by RajoRacer » Tue May 14, 2024 4:22 pm
November of 1925 - paragraph 119.
Post by speedytinc » Tue May 14, 2024 5:19 pm
I disagree with omitting that 2nd bushing.
That puts all the load/weight of the drum pack on the smallest & fastest wearing bushing.
Ford omitted this in late production. To save 1/2 cent per unit? Why the change after 13 or 14 million units?
If you have rebuilt the transmission correctly, alignment wont be an issue.
Last Name: Hatch
Post by Dan Hatch » Tue May 14, 2024 7:39 pm
Thanks Steve, I’ll look it up when I get home.
RGould1910
Last Name: Gould
Post by RGould1910 » Tue May 14, 2024 8:06 pm
I agree with you, John but its worth pointing out that the 26-7 style driving plate is captured inside the brake drum and is way more secure than the earlier version where there is always a degree of slop in the lip that secures the driving plate to the brake drum, making the second bushing a necessity to hold alignment.
I have heard of rebuilders omitting the middle bushings thinking its not necessary even in pre 26 transmissions because Ford omitted it in late 25. In my thinking that is a big mistake.
BTW its pretty easy and inexpensive to make a driving plate alighment reamer pattered after the KRWilson reamer that indexes off the two brake drum bushings. Ive made a couple.
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Tue May 14, 2024 8:11 pm
After they omitted the rear bushing I’m pretty sure that a matter of months later they began installing it again… It’s not good engineering to leave it out. The driven gear shaft needs that extra support.
Post by RajoRacer » Tue May 14, 2024 8:44 pm
Can you verify your assumption, Adam ?
J and M Machine
Last Name: Gulbankian
Post by J and M Machine » Wed May 15, 2024 8:55 am
I too have seen late original drums with one bushing installed .
However I've always installed two .
Makes more sense to have two installed rather than only one with the amount of load on main shaft, two share the load.
My high school drafting teacher told us; "Engineer may design it but takes a machinist to make it work".
www.jandm-machine.com
https://www.jandm-machine.com/for_sale.html
Last edited by J and M Machine on Wed May 15, 2024 12:07 pm, edited 1 time in total.
Post by Jerry VanOoteghem » Wed May 15, 2024 9:33 am
Give them what they want, in place of what they ask for. ;)
