Hand Brake / Brake Lever Differences...
BRENT in 10-uh-C
First Name: Brent
Last Name: Terry
* REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1914 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
Post by BRENT in 10-uh-C » Wed May 15, 2024 9:05 am
I am looking for a Hand Brake Lever suitable for a '09/10 that is nice enough that I can have brass-plated. Bruce doesn't mention much about the structural differences between the years, and I didn't see anything in the Judging Guidelines either, -so is there any differences in the shapes of the lever (-not the cross-shaft or cam) that I should be looking for to look aesthetically correct??
TIA
Re: Hand Brake / Brake Lever Differences...
Post by TRDxB2 » Wed May 15, 2024 10:45 am
TIA
Past discussion with detailed pictures
https://www.mtfca.com/discus/messages/7 ... 1505093903
BRENT in 10-uh-C
First Name: Brent
Last Name: Terry
Post by BRENT in 10-uh-C » Wed May 15, 2024 1:02 pm
Thank you!
Post by Original Smith » Wed May 15, 2024 1:07 pm
I have two late ones. On one, the lever is straight, and on the other it is bent in toward the door.
Post by Allan » Wed May 15, 2024 10:03 pm
One addition to my observations in the link Frank supplied. The flat headed clevis pins were also brass plated. I found traces of the plating on the pins of the assembly I discovered.
