Copper intake/exhaust rings
Topic author - Posts: 366
- First Name: Bill
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1916 Model T Touring
- Board Member Since: 2006
Are the crushable copper intake/exhaust rings reusable? I’m thinking not, but I’d like to be certain.
- Last Name: House
Re: Copper intake/exhaust rings
I wouldn’t - once they’ve lost the designed utility of being crushed by manifolds…. I do reuse cotter keys tho’
Not reuseable.
- Last Name: Patrick
No. They are designed to assume the irregularities (such as rust pits) of the surface they are pressed into. If they are rotated or transferred to a different port, the surface changes and they can no longer seal properly.
- First Name: Bill
Thanks for the confirmation: I thought they were one and done!
- First Name: Les
- Last Name: Schubert
I have reused them when I’ve had do repairs on a road trip. The important thing is to retorque them HOT on reassembly and possibly more than once
- First Name: Edward
- Last Name: Baudoux
If they're not seriously deformed, anneal them by stringing them on a piece of wire, hearing them red with a torch, and quenching them in water. They'll be soft enough for reuse.
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
It may be overkill, but I smear some hi-temp RTV on them, especially if the engine surface has any pitting.
