Throttle slippage
Last Name: Juhl
Throttle slippage
Post by Oldav8tor » Sun May 26, 2024 12:22 pm
Anybody got the pattern for making that block that is meant to reduce throttle and spark lever slippage? They don't appear to be available anymore.
Re: Throttle slippage
Post by DanTreace » Sun May 26, 2024 1:22 pm
Older post from 2019 with dimensions of one T'ers wood work to make one of these contraptions :)
https://www.mtfca.com/phpBB3/viewtopic.php?t=4693
Usually a small adjustable wrench, fitted to the quadrant, will lift or bend up the quadrant in a spot that 'tightens' the lever against the grooves in the quadrant arm to prevent slippage.
