applying Spar varnish to firewall
frank.koonce
Last Name: Koonce
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Roadster, 1927 fordor
Post by frank.koonce » Sun May 26, 2024 6:26 pm
I found a post on this forum a couple of years ago about applying thinned Spar varnish to the firewall with a cloth, and it worked great. I want to do it again for another car but I can't remember if it should be a 50/50 percentage or something else. Also, I can't remember if I used turpentine or mineral spirits the first time. Recommendations welcome!
First Name: Adrian
Last Name: Whiteman
Re: applying Spar varnish to firewall
Post by A Whiteman » Sun May 26, 2024 7:32 pm
Hi Frank, I would suggest using the thinners given on the varnish tin as different manufacturers can use different bases. Try the thinning ratio on a bit of scrap wood and see what works for you.
Cheers
See this post as well: https://www.mtfca.com/discus/messages/1 ... 69404.html
and this one: https://www.mtfca.com/phpBB3/viewtopic.php?t=23013
Post by Allan » Sun May 26, 2024 8:08 pm
Penetrol is a product made to thin paints and extend brushing time to allow even coating. You just need to check that it is compatible with the product you want to use.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Sun May 26, 2024 8:40 pm
What Allan said. Urethane varnishes don’t thin well and are best used at package consistency. They don’t behave like the natural resin long oil varnishes of yore. Any road, a new-fangled foam brush would be a far better applicator than a rag.
Get a horse !
frank.koonce
Last Name: Koonce
Post by frank.koonce » Mon May 27, 2024 5:01 pm
Thanks to everyone who responded to my question about using Spar varnish. Much appreciated!
