Lube or dry?
Last Name: Juhl
Lube or dry?
Post by Oldav8tor » Thu Jun 06, 2019 1:59 am
When installing rear wheels on axles do you put any oil or grease on the axle or leave it dry?
Last Name: van Ekeren
Re: Lube or dry?
Post by Kerry » Thu Jun 06, 2019 3:16 am
Keywayed taper shaft/hub are ment to be a dry fit.
Re: Lube or dry?
Post by Allan » Thu Jun 06, 2019 3:33 am
Dry!
Aĺlan from down under.
Hal
First Name: Hal
Last Name: Davis
* REQUIRED* Type and Year of Model Ts owned: '22 TT Stake Bed, '18 Touring (Hers)
Re: Lube or dry?
Post by Hal » Thu Jun 06, 2019 7:35 am
Yep, what they said. If you put grease on there, it takes up some amount of space. then when you drive, some of that will work its way out. Now you have a loose fit.
Last Name: Juhl
Re: Lube or dry?
Post by Oldav8tor » Thu Jun 06, 2019 9:47 pm
Thanks! Makes sense.
Re: Lube or dry?
Post by Allan » Sat Jun 08, 2019 9:35 pm
The fit of components on a tapered axle relies in friction to remain tight. The key is used to stop them moving. Using any kind of lubricant will reduce that friction, thus compromising the fitting. It is tempting to use something to make removal easier, but it defeats the purpose.
