Rear axle question
Last Name: Hjortnaes
Rear axle question
Post by DHort » Mon Jun 03, 2024 1:08 am
If you are installing the old axle seal you will use the steel washer outbound of the hyatt bearing.
If you are using the modern axle seal with o rings, do you still install the steel washer?
JohnH
Last Name: Hunter
Board Member Since: 2002
Re: Rear axle question
Post by JohnH » Mon Jun 03, 2024 2:47 am
No, the steel washer is not used. It keeps the bearing and felt in position for the original type seal. The modern seal keeps the bearing in position by itself.
