Wanted: Brass era licence plate / tail light bracket like Neverout
neilson604
First Name: Harry
Last Name: Neilson
* REQUIRED* Type and Year of Model Ts owned: 1917 Model T
Post by neilson604 » Wed Jun 05, 2024 2:47 pm
I'm looking for a period accessory license plate / tail light bracket for our big 1908 Welch touring car. Patent dates may go later.
Anything like the brass Neverout or other period examples would compliment the car. Example on an EMF shown.
hhneilson@gmail.com
ModelT46
First Name: Darel
Last Name: Leipold
Re: Wanted: Brass era licence plate / tail light bracket like Neverout
Post by ModelT46 » Wed Jun 05, 2024 6:02 pm
the original Neverout brackets were forged or cast iron, I never have seen a brass one.
RGould1910
Last Name: Gould
Post by RGould1910 » Wed Jun 05, 2024 6:32 pm
A forging, I was able to bend mine. It was not a Neverout but one that attached to the Ford bracket.
A400
Last Name: OBrien
* REQUIRED* Type and Year of Model Ts owned: 1913 touring
Post by A400 » Wed Jun 05, 2024 8:27 pm
They turn up on Ebay occasionally. I bought a NOS stock one there a few years ago.
robert daniello
Last Name: D
Post by robert daniello » Wed Jun 05, 2024 9:43 pm
Neverouts were made in brass and iron, original brass ones are very tough to find. I have never seen one for sale off of a car. The brass originals that I have seen have all had round tapered tail lamp posts rather than a blade style. Originals also had patent dates stamped into the brass in addition to the raised lettering in the casting. Other than those differences the reproductions are very good, and a lot easier to get unless or until you stumble across an original. Iron originals still turn up fairly often, but they seem to have increased in value recently.
Larry
Last Name: Gresh
Post by Larry » Thu Jun 06, 2024 7:40 pm
Harry,
I sent you an email through the form but was unable to post the pictures to it so I will put them here.
neilson604
First Name: Harry
Last Name: Neilson
Post by neilson604 » Fri Jun 07, 2024 12:16 pm
Thanks for the offer Larry I’d take it if it had the post and not spade attachment.
Harry
Larry
Last Name: Gresh
Post by Larry » Fri Jun 07, 2024 2:32 pm
Harry,
The bracket is designed for use with either the post or spade.
Attached is an additional photo of the bracket.
Larry
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Fri Jun 07, 2024 4:35 pm
The receiver on the Neverout brackets were designed so they could mounted on either a round or spade post as indicate above.
However, there were two basic styles as far as the post on the Neverout bracket itself is concerned - round or spade.
Click on the ad below to enlarge.
Larry
Last Name: Gresh
Post by Larry » Fri Jun 07, 2024 6:34 pm
Eric,
If I understand Harry correctly, He was concerned about the receiver and this bracket would work for the spade or post. The picture you posted shows the spade and post for hanging the light. The picture Harry posted has a light that would use the spade and not the post.
