Strange Looking Tools
BarnesvilleT
Topic author - Posts: 101
- First Name: William
- Last Name: Hallada
- * REQUIRED* Type and Year of Model Ts owned: 1926 Model T Coupe
Can anyone ID these tools. There is no Ford logo on them.
They were in a box of wrenches that I purchased.
Pep C Strebeck
- First Name: Joseph
- Last Name: M
Re: Strange Looking Tools
I can't speak to the top one, but the bottom is a pair of upholstery pliers.
The top one may be an exhaust flange nut wrench.
BarnesvilleT
I guess I should have added some dimensions. The top tool is only about 4.5" long and the opening
is about 1 3/8". It might not even be for a car. I have attached a cropped version to show the letters and part number.
Bill Dizer
- First Name: Bill
- Last Name: Dizer
- Board Member Since: 2014
The bottom tool is a horse shoe nail set. After the nails are driven through the hoof and are sticking out, the nail is cut off and those pliers bend the remainder of the nail over, then the hammer part finishes setting the nail end in the hoof.
BarnesvilleT
Hey Bill,
I have a friend that does just that so I think I will get a hold of him to see if
he is interested in the tool. Thanks for the info.
Bill H.
Bill H.
ThreePedalTapDancer
- First Name: Ed
- Last Name: Martin
It is a common tool called a Cobblers Plier for making shoes.
John E. Guitar
- Last Name: Guitar
- Board Member Since: 2012
Could the first one be a wheel hub spanner? It looks like it says Continental 25254C, maybe Continental Tyres?
BarnesvilleT
There is a Continental Tire plant right here in Barnesville.
I will check with them to see if any one can ID it.
Thanks,
Bill
Thanks,
Bill
- Last Name: Juhl
Continental also makes aircraft engines although I can't guess what that wrench would fit.
BarnesvilleT
It looks like this thread has come to an end and had nothing to do with a Model T.
I sent a photo of the first tool to the local Continental Tire Plant and they contacted an older employee
who confirmed it is a cousin of the the tool in the photo I added. It was a specialty tool used in tight spots and
"around corners". Thanks for the input.
Bill
Bill
- Attachments
- image001.png (16.81 KiB) Viewed 3306 times
