Tail lamp
Bodyman.315
Topic author - Posts: 9
- First Name: Eric
- Last Name: Pfendler
- * REQUIRED* Type and Year of Model Ts owned: 1927 Tudor 1925 C Cab Snowmobile
Tail lamp
Wtb 4inch drum style brake light lens.
Drew Wommack
- First Name: Drew
- Last Name: Wommack
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1922 Touring, 1923 Speedster, 1925 Roadster, 1926 Touring
Re: Tail lamp
If you are speaking of the '26-'27 original Ford accessory tail light, repro lenses for those are available through Myers Early Dodge
https://www.mtfca.com/discus/messages/5 ... 1434302489
https://www.myersearlydodge.com/image.p ... CN2599.JPG
- Last Name: Hjortnaes
Re: Tail lamp
I suggest you put this on the classified page and preface the topic with WTB.
Re: Tail lamp
There were hundreds of after-market brake lights for model Ts and other cars in the 1910s. 1920s, through and after WW2 even that can be used. There were likely dozens of them that were about four inch in size one way or another.
Do you want one that says "STOP"? Flat? Convex?
We want to help you. But you need to help us to help you.
One of my speedsters years ago, I wanted to use a nice original after-market tail light I had, that was missing the lens. I had had it a couple years and never did find an original lens that would fit it. So I went to the local auto parts store and bought a modern replacement trailer tail light lens. It was large enough, slightly convex, and I cut it and shaped it to fit my light. It looked fine, and worked GREAT! The plastic didn't block the light so much like the original glass did, so it looked good dark, but lit up really bright! A good thing for a brake light.
Just a thought.
And people think I am a purist?
Just a thought.
