Brake band adjustment
Allen Banks
First Name: Allen
Last Name: Banks
* REQUIRED* Type and Year of Model Ts owned: 1923 Roadster
Post by Allen Banks » Thu Jun 06, 2019 5:42 pm
Novice question, but how do you tighten up the nut and have the washer follow so the notches line up? I tighten the nut but the washer stays put. ???
Re: Brake band adjustment
Post by RajoRacer » Thu Jun 06, 2019 5:51 pm
Yes, the washer is notched and stays in the pedal shaft slot.
Post by RajoRacer » Thu Jun 06, 2019 5:52 pm
Also - you will "feel" when the notch in the nut engages the washer protrusion - they're 180 degrees apart.
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Thu Jun 06, 2019 6:00 pm
What Steve said, in other words, you can only adjust the brake and reverse half a turn at a time.
Allen Banks
First Name: Allen
Last Name: Banks
Post by Allen Banks » Thu Jun 06, 2019 6:25 pm
Got it! Thanks guys!
