Floating rear axle hub kit F/S
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Sun Jun 16, 2024 2:06 pm
This new never installed kit replaces the Hyatt outer roller rear axle bearing with a sealed large ball bearing. It also provides a modern seal on the axle shaft to stop differential lube from leaking onto the brakes. This kit does both left and right rear axles. The bearing mounts have 6 holes so are intended for wood wheels ( that includes accessory wire and disc wheels that use standard 6 bolt pattern drums). If you are using 1926-27 Ford wire wheels with 5 bolts, the bearing mounts could be re-drilled to that pattern. Asking price is $475 which includes domestic shipping. The estate's loss is your gain, see catalog prices! Only this one set so when gone there will be no other available here.
Layden Butler
First Name: Layden
Last Name: Butler
Re: Floating rear axle hub kit F/S
Post by Layden Butler » Tue Jul 09, 2024 2:54 pm
$475 including shipping!
