WTB - Rebuildable 1926-27 Model T engine block s/n 12222529 or higher
joeoldcars
First Name: Joe
Last Name: Rush
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1926 Touring
Post by joeoldcars » Sat Jun 29, 2024 8:29 am
Looking to purchase a rebuildable 1926-27 type Model T engine block to replace one on my engine that cracked through coolant cavity into and top of valve gallery. I have obtained 3 so far, cleaned and crack inspected and found all three with cracks around valve seats heading down to the same area that can’t be used or reliably repaired. Goal is to build this into an engine that will get about 1,200 miles per year (not a trailer queen). Possible exchange location is MTFCI Tour in Cadillac Michigan in July 2024.
Last Name: Wrenn
Re: WTB - Rebuildable 1926-27 Model T engine block s/n 12990077 or higher
Post by TWrenn » Sat Jun 29, 2024 11:28 am
Yeh that's the problem with 26/7 engines...thats their Achilles heel. I have a 26 block but not sure of the number let alone the viability of it. Once it gets done pouring down rain I'll go to the barn & check. It's sitting under another earlier block and blocked by ju k so you know how that goes! Ha ha
colonelpowers
First Name: Joshua
Last Name: Powers
* REQUIRED* Type and Year of Model Ts owned: 1922 Center Door Sedan
Post by colonelpowers » Sat Jun 29, 2024 1:29 pm
I sent you an email.
RandyB
First Name: Randy
Last Name: Behrens
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T Coupe
Re: WTB - Rebuildable 1926-27 Model T engine block s/n 12222529 or higher
Post by RandyB » Sat Jun 29, 2024 10:37 pm
I sent a message about a block you may be interested in.
Tim D
Last Name: Dickson
* REQUIRED* Type and Year of Model Ts owned: 1912 speedster 1911 Torepdo
Post by Tim D » Sun Jun 30, 2024 11:30 am
have one in Beloit WI
Post by Original Smith » Sun Jun 30, 2024 1:17 pm
Along time ago, I had a 26 block with the boss, but not drilled! I have a very late 1925 runabout with a 12,000,000 serial number, and as far as I know they used them during the month of July and early August.
Steve King
Last Name: King
* REQUIRED* Type and Year of Model Ts owned: 14 Touring, 25 Coupe, , 26 Touring, 22 Aluminum Fordor, 23 Coupe
Board Member Since: 2010
Post by Steve King » Tue Jul 02, 2024 2:42 pm
I roughed mine up and applied Belzona 1311. I'm running it. All that headache rebuilding, I was determined to make it work. I'm also running water for the summer to allow the interior of the crack to rust.
Last Name: Tannehill
Board Member Since: 2002
Post by JTT3 » Tue Jul 02, 2024 3:05 pm
Steve that stuff is expensive but it’s awesome. Much cheaper than a tear down & rebuild. This stuff is used in the oilfield in high pressure systems & is considered a permanent repair.
JOE DONT WORRY ABOUT THE NUMBER THAT CAN BE FIXED USING YOUR CURRENT NUMBER.
Best John
joeoldcars
First Name: Joe
Last Name: Rush
Post by joeoldcars » Fri Jul 05, 2024 4:12 pm
Still looking for a good 26-27 Ford Model T engine block. Any additional leads are welcome.
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Sat Jul 06, 2024 7:18 am
I have several to look at already tore down give me a jingle Tiffin Ohio
