WTB one wood coil.
Tim D
Last Name: Dickson
* REQUIRED* Type and Year of Model Ts owned: 1912 speedster 1911 Torepdo
WTB one wood coil.
Post by Tim D » Tue Jul 02, 2024 11:06 am
WTB one rebuilt wood coil or one that just needs a cap. In Wisconsin. Thanks
Last Name: Wrenn
Re: WTB one wood coil.
Post by TWrenn » Tue Jul 02, 2024 11:50 am
Contact Brent Mize or Ron Patterson
Karl Von Neumann
First Name: Karl
Last Name: VonNeumann
Board Member Since: 2022
Post by Karl Von Neumann » Tue Jul 02, 2024 12:58 pm
Tim I've got a big box of coils here some work some don't pleasant prairie area
Tim D
Last Name: Dickson
Post by Tim D » Tue Jul 02, 2024 3:22 pm
thanks have one coming from Adam.
Kajtek1
First Name: Kris
Last Name: Pawlak
* REQUIRED* Type and Year of Model Ts owned: 1922
Post by Kajtek1 » Sat Sep 14, 2024 7:01 pm
Can you measure the resistance on side prongs?
I bought couple of coils on ebay and they show open circuit, what means bad wires.
I can replace condenser, but not the coil.
Karl Von Neumann
First Name: Karl
Post by Karl Von Neumann » Mon Sep 16, 2024 11:02 am
I sold all the good coils I had and just got in another small batch but haven't had time to go thru them yet
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Mon Sep 16, 2024 12:49 pm
Another give away for the coil is whether the slide off side has two small nails to hold it in place or a staple.
The ones with the nails have Ford at the top or perhaps if older, in the center of the other side.
I have found coils that make sparks on the Hand Crank Coil Tester with no sparks showing on the StroboSpark Coil Tester.
They always seem to be the ones with the staples and measuring the secondary winding with an ohm meter will show about 2,8000 Ohms or a little less, and they will work in a Model T Coil Box, with a little less hot spark value..
The ones marked Ford all seem to be right at the 3,300 Ohms that appear to be correct and they will always produce the 2,500 Volts that the StroboSpark has to read to light the three bars.
