26-27 fuel valve
GG Gregory
First Name: GG
Last Name: Gregory
* REQUIRED* Type and Year of Model Ts owned: 27 Roadster
26-27 fuel valve
Post by GG Gregory » Tue Jul 02, 2024 7:55 pm
The fuel valve on my 27 Roadster has gotten impossible to turn off or on. Before I installed it about 4 years ago I lapped the brass valve with lapping compound and it’s worked great, easily turned and no leaks. Well I still have no leaks but it’s very stiff. Will it need to be lapped every so often to keep it operating?
Moxie26
Last Name: Jablonski
Re: 26-27 fuel valve
Post by Moxie26 » Tue Jul 02, 2024 8:15 pm
Just back off on the valve pack nut a little bit so you can turn the valve. Be sure you have a a quart plastic container underneath to catch leakage you may have while the pack nut is loose.
GG Gregory
First Name: GG
Last Name: Gregory
Post by GG Gregory » Tue Jul 02, 2024 8:20 pm
I did that and it didn’t help, I didn’t have it really tight to begin with. The only thing that did help was once I backed off the packing nut I pulled out on the valve and it would then turn but once I put the nut back on and barely tightened the nut, just enough to keep it falling off it locks up again.
Moxie26
Post by Moxie26 » Tue Jul 02, 2024 8:27 pm
May have to take the valve apart. Rotate some crocus cloth inside the cast iron housing for the valve. Do the same on the valve surface of the brass valve itself. Rinse with solvent of your choice . Polish to make smooth, then reassemble with a schmeere of anti-seize and a new lead gasket.
First Name: craig
Last Name: leach
Post by Craig Leach » Tue Jul 02, 2024 8:33 pm
Have you tried Timesaver? the aircraft industry has BASO & EZTURN gas valve grease made just for this but have a firm grip on your wallet.
RGould1910
Last Name: Gould
Post by RGould1910 » Tue Jul 02, 2024 9:03 pm
Langs sells a valve lube that worked for me. I used Timesaver first.
GG Gregory
First Name: GG
Last Name: Gregory
Post by GG Gregory » Tue Jul 02, 2024 10:31 pm
I used Timesaver when I first polished the valve.
jiminbartow
Last Name: Patrick
Post by jiminbartow » Tue Jul 02, 2024 11:24 pm
If lapping the valve worked before, take it apart and lap it whenever it binds up, but only enough to clean off the buildup and apply a dab of grease to the valve when assembling. Jim Patrick
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Wed Jul 03, 2024 10:35 am
This works very well. No seizing, and turns well. No leaks.
Post by Norman Kling » Wed Jul 03, 2024 11:19 am
I have found that our modern fuels tend to get thick like varnish when they get a few months old. I have even had the choke valve on the carburetor stick. At first I wondered why the car would not start when cold, and ran rough when warm? The choke was neither closing completely nor opening fully. so I cleaned it up and it works fine and runs smoothly. Sometimes it can even clog the jets and passages in the carburetor or plug the fuel line. The same thing can happen to the fuel valve when you don't use the car often. So after you get it cleaned up, open it and close it more often even if you don't drive the car every day. A little bit of bar soap makes a good lubricant. problem with grease is that it is soluble with gas.
GG Gregory
First Name: GG
Last Name: Gregory
Post by GG Gregory » Wed Jul 03, 2024 12:29 pm
I use non ethanol gas 95% of the time, I thought that would reduce the buildup of varnish. I’ll remove the valve and clean/lap it.
NoelChico
First Name: Noel
Last Name: Chicoine
Post by NoelChico » Wed Jul 03, 2024 3:08 pm
There’s a lube for gasoline petcocks that fixes both leaks and tight turning. It only comes in 1 oz. tubes so a tube will last your club a lifetime.
Post by Norman Kling » Wed Jul 03, 2024 3:59 pm
Only the California prescribed formula gas is available here. There is Summer blend and winter blend.
