Pack nut accessory clamp
Mopar_man
Last Name: Govoni
Post by Mopar_man » Wed Jul 03, 2024 9:06 pm
Anyone know where i can get one? Seems Rattles is living up to his name. Everyplace seems to be out of stock. I know I can make one but I'd like to get the accessory if someone has one.
Rob
Last Name: Hjortnaes
Re: Pack nut accessory clamp
Post by DHort » Thu Jul 04, 2024 8:25 pm
You can make one with a hose clamp and a bent piece of metal. That is all they are.
Post by speedytinc » Thu Jul 04, 2024 9:27 pm
Nut, manifold or both threads must be weak. Clamps are not necessary with good parts.
A little anti-seize & get real tight should do the job with no clamp needed.
Ed Fuller
First Name: Ed
Last Name: Fuller
Board Member Since: 2012
Post by Ed Fuller » Thu Jul 04, 2024 10:26 pm
You don’t even need to bother with the bent piece of metal. Just put a hose clamp around the exhaust pipe and tighten it right up against the nut.
Post by Jerry VanOoteghem » Fri Jul 05, 2024 8:46 am
How does that prevent the nut from turning?
Post by Jerry VanOoteghem » Fri Jul 05, 2024 8:49 am
"Real tight" is nice, but don't go nuts. You'd be surprised how thin the manifold casting is. Once you break one off, you'll be surprised. (No, not me. I break mine by dropping them :roll: )
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Fri Jul 05, 2024 10:55 am
Anything, including a hose clamp or even a 1 1/2" muffler clamp, placed as close to the exhaust nut as possible, will keep the nut from turning and backing off, or if no threads, from falling off. The theory is the same as double nutting a bolt tor stud to keep the first nut from backing off.
Mopar_man
Last Name: Govoni
Post by Mopar_man » Fri Jul 05, 2024 5:07 pm
I found that Texas T parts have them. The nut is new but I bet the manifold threads are not that good. Thanks for all the input.
Ed Fuller
First Name: Ed
Last Name: Fuller
Post by Ed Fuller » Sat Jul 06, 2024 10:40 am
Jerry, like Terry Woods said. A hose clamp installed on the pipe and jammed right up against the back of the nut will keep the nut from backing off.
