Anderson timer lubrication
JimKelsey
First Name: Jim
Last Name: Kelsey
* REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Tudor
Board Member Since: 2010
Post by JimKelsey » Sat Jun 08, 2019 8:53 pm
For those of you that use the Anderson timer, what type of lubrication do you use that gets the best conductivity?
Re: Anderson timer lubrication
Post by Scott_Conger » Sat Jun 08, 2019 9:06 pm
Jim, I use white marine grease...I do not pack it...I just place a very small schmear on the flapper and 4 conductors. I clean it annually. The timer on my driver is 7 years old and shows very little wear.
