E-Timer
jamlip
Last Name: Lipman
* REQUIRED* Type and Year of Model Ts owned: 1921 Touring
E-Timer
Post by jamlip » Fri Jul 05, 2024 9:59 pm
E-Timer, light use, $400.
Used on my car for a couple of years. Works beautifully. Can mail.
James
Tel: 310.Twenty-Two.Seven.Sixty-5.Twenty-5
RVA23T
Last Name: C
Re: E-Timer
Post by RVA23T » Fri Jul 05, 2024 10:36 pm
Whoever purchases this unit, there is a 0.05” Spacer Shim that you may or may not need when installing the Vane Actuator Assembly (Replaces Roller) on the cam. It is not shown in the picture.
Is it still on the car James???
Bruce Compton
First Name: Bruce
Last Name: Compton
* REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
Re: E-Timer
Post by Bruce Compton » Sat Jul 06, 2024 3:07 pm
James, I'm interested. Does it have the spacer mentioned and the wiring diagram with it? Bruce
