Still hoping
KenHaverhill
First Name: Kenneth
Last Name: LeBlanc
* REQUIRED* Type and Year of Model Ts owned: 27 coupe 23 touring 26 TT Snowmobile 22 TT Dump Truck 26 Fordoor
Still hoping
Post by KenHaverhill » Sun Jun 09, 2019 6:39 am
Still hoping someone can provide a picture of the wood door over tool tray on a TT closed cab thanks
Gordon C
First Name: Gordon
Last Name: Clayton
* REQUIRED* Type and Year of Model Ts owned: 27 TT
Re: Still hoping
Post by Gordon C » Sun Jun 09, 2019 10:57 am
Me Too
G. Clayton Miller, Mo.
mvweaver
First Name: Matthew
Last Name: Weaver
* REQUIRED* Type and Year of Model Ts owned: 27 Model TT flatbed and 27 Model TT dump
Re: Still hoping
Post by mvweaver » Mon Jun 10, 2019 3:56 pm
I'll try to get you guys some pictures of the original one in mine. I can tell you it's not so much a door as it is a spacer to keep the seat springs snug. It's only about 1 1/2" - 2" wide and cut with a bevel on one side. Will see what I can do about pictures a little later. - Matt
mvweaver
First Name: Matthew
Last Name: Weaver
Re: Still hoping
Post by mvweaver » Mon Jun 10, 2019 5:48 pm
Here's the best I could do one handed. My building is pretty dark so I got measurements for you. They should be within 1/16". The board is 50" wide and is centered in the cab with about 1/2" between the end and side of the cab on both sides.The front edge is kind of bullnosed so that the bottom of the seat spring can sit back against it. If I get more time and can pull the truck out later this week I'll get some photos of the actual board.
Model TT steel cab tool box board.jpg (21.26 KiB) Viewed 4994 times
Gordon C
First Name: Gordon
Last Name: Clayton
Re: Still hoping
Post by Gordon C » Tue Jun 11, 2019 11:01 am
THANKS A BUNCH MATT !!!!!!!!
I had no idea what it looked like or how wide it was. I was thinking maybe it went all the way
over the entire seat.
really appreciate your help. Thanks again
Gordon Clayton Miller, Missouri
mvweaver
First Name: Matthew
Last Name: Weaver
Re: Still hoping
Post by mvweaver » Tue Jun 11, 2019 11:30 am
You're welcome Gordon. If I get a chance I did take some pictures just not that great. - Matt
KenHaverhill
First Name: Kenneth
Last Name: LeBlanc
Re: Still hoping
Post by KenHaverhill » Tue Jun 11, 2019 5:27 pm
Thanks Matt it's a big help ,ken
mvweaver
First Name: Matthew
Last Name: Weaver
Re: Still hoping
Post by mvweaver » Wed Jun 12, 2019 8:56 am
I forgot to add, the long side of the board goes down with the flat lip so that the bottom seat spring sets up against it. I'm guessing the bevel is there to allow the spring to slide down into place. - Matt
