F-S KW SWITCH
Topic author - Posts: 818
- Last Name: Iaccino
- * REQUIRED* Type and Year of Model Ts owned: 1911 Roadster, Open Runnabout
F-S KW SWITCH
KW switch. Works, key does not withdraw from switch. Fits Master Vibrator and 1913 coil box. Needs coil box front plate. $85 plus flat rate shipping.
USA only.
USA only.
Re: F-S KW SWITCH
Will the upper screw hole still hold a screw? They are 6-32.
Re: F-S KW SWITCH
yes, did not have a screw for the hole.
Re: F-S KW SWITCH
please re-post
Re: F-S KW SWITCH
please re-post
Re: F-S KW SWITCH
please re-post
Re: F-S KW SWITCH
please re-post
Re: F-S KW SWITCH
Please re-post
Re: F-S KW SWITCH
Please re-post
