wtb rear set of ubolts Found
Topic author - Posts: 500
- First Name: Clay
- Last Name: Atkins
- * REQUIRED* Type and Year of Model Ts owned: 1921 Roadster
Looking for a set of ubolts for rear spring attachment to frame.
Working on 26 frame.
Please pm if you have a set.
Thanks,
Clay
Thanks,
Clay
- First Name: Tom
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1921 Speedster 1927 speedster
- Board Member Since: 2013
Re: wtb rear set of ubolts
I may have a set. I will take a look in the parts bin and get back to you on the forum. Tom
Spring leave count makes a difference - FYI.
- Last Name: House
Are rear ‘26-‘27 spring U bolts different than earlier ? If not, I have a bunch I’d send you a pair if Tom doesn’t.
- First Name: Clay
- Last Name: Atkins
My spring is 9 leaf.
- Last Name: Hjortnaes
If he has a gooseneck he definitely needs the long ones.
Long ones are 4 in
- First Name: Tom
Clay:
I have the rear spring clamps that you asked about. They are for the 9 leaf spring. I will take $20.00 for the pair. Postage at it's cost. i Will send pictures if you want to purchase.
I also have the shorter clips for the 8 leaf spring at the same price.
- First Name: Clay
- Last Name: Atkins
Please send pictures.
Thanks, Clay
Thanks, Clay
- First Name: Tom
Clay:
Here is a picture of the rear spring bolts with the mounting pieces and two nuts. I don't have the other two nuts, Tom
- First Name: Clay
- Last Name: Atkins
Okay, I will send address in pm.
Thanks,
Clay
Thanks,
Clay
