ANCO Timer Lube
Gracie'sDad
Last Name: Dow
ANCO Timer Lube
Post by Gracie'sDad » Tue Jul 16, 2024 11:38 am
What does everyone use for non conductive lube for their ANCO timers? I've used a blob of Vaseline for years with no problems. Is there something better?
Re: ANCO Timer Lube
Post by RajoRacer » Tue Jul 16, 2024 1:42 pm
I believe this is a type of "high pressure" lube - it's what I use - https://www.modeltford.com/item/3221LUB.aspx
Gracie'sDad
Last Name: Dow
Re: ANCO Timer Lube
Post by Gracie'sDad » Tue Jul 16, 2024 3:13 pm
I wonder how this stuff's properties differ from Vaseline......
Re: ANCO Timer Lube
Post by Steve Jelf » Tue Jul 16, 2024 3:57 pm
Vaseline was certainly around during the Model T era. Haven't I seen I seen a published recommendation to use it on a T? Ford? Fahnestock? Gasoline Alley?
