FS wire front hubs dammaged
Karl Von Neumann
Topic author - Posts: 761
- First Name: Karl
- Last Name: VonNeumann
- * REQUIRED* Type and Year of Model Ts owned: 1916 touring 1927 tudor 1926 hotrod 1913 speedster (project) 1926 coupe (project)
- Board Member Since: 2022
I have a pair of dammaged front hubs fix or use as shop rollers. One has a crack outside bearing race some one has welded it up poorly I guess it could be fixed the other one the front is smashed where the grease cap goes that one will probably be ok with some work $250 shipped lower 48
Karl Von Neumann
- First Name: Karl
Karl Von Neumann
- First Name: Karl
