reproduction wood coil box lid
Colin Mavins
First Name: Colin
Last Name: Mavins
Post by Colin Mavins » Sat Jul 27, 2024 4:48 pm
Is there somebody out there making new wood coil box lids I need one for a 1912 kingston coil box Thanks Colin
Last Name: Tannehill
Board Member Since: 2002
Re: reproduction wood coil box lid
Post by JTT3 » Sat Jul 27, 2024 6:04 pm
Colin I think Langs sells the lid as a separate item if not mistaken.
https://www.modeltford.com/item/4230.aspx
Post by speedytinc » Sat Jul 27, 2024 6:10 pm
I would think the possibility of any other lid fitting would be a long shot. Best you could hope for is it be slightly oversize to modify to fit.
Were I in this situation, I would visit my local cabinet maker & have one made. @ that, the best match would be to remake the body & lid together.
Colin Mavins
First Name: Colin
Last Name: Mavins
Post by Colin Mavins » Sat Jul 27, 2024 6:46 pm
Thank you I did go to langs it showed only the complete box I will contact them . yes I was looking at making a new front for the lid the other 3 sides are good I can make it but it will take some time Im always looking for the easy way out.
Last Name: House
Post by George House » Sat Jul 27, 2024 7:42 pm
John, wasn’t Ludwig Gocek of Nazareth PA known for making very early wood coil boxes ? Unfortunately he died 4 years ago. Did anybody pick up the torch? I think he made the 2 cyl. Splitdorf coil box for my ‘10 Maxwell.
Post by Allan » Sat Jul 27, 2024 7:46 pm
I agree with John. When i lost the lid off my Heinze box somewhere over the Hay Plains, I borrowed an original lid and accurately duplicated it, only to find my coilbox was almost 1/8" wider than my new lid. A custom made lid is called for.
Tbird
Last Name: Bird
Post by Tbird » Sat Jul 27, 2024 8:26 pm
I would check with John Anderson (RV’s brother) he made all the coil boxes and floor boards.
BigAl
First Name: Alan
Last Name: Stein
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring (August 1911)
Post by BigAl » Sun Jul 28, 2024 5:14 pm
Unfortunately R.V. Anderson pasted away about a year and a half ago. He was a master at restoring and reproducing early coil boxes and coils. His brother made the boxes for him. His name is John Anderson, lives in Gerry, NY. He shouldn’t be hard to find, maybe he took over R V’s old number. He does exceptional work.
Last Name: Juhl
Post by Oldav8tor » Sun Jul 28, 2024 9:49 pm
Jonathan Anderson <jpautowood@gmail.com> 716-nine-eight-five-5880
TMiller6
First Name: Thomas
Last Name: Miller
Board Member Since: 2006
Post by TMiller6 » Sun Jul 28, 2024 11:07 pm
My son’s car has a 1912 Heinze box with a new lid. The reproduction fit the original box perfectly. It was supplied with two loose pieces to glue in and hold the coils in place.
I believe Jonathan Anderson supplied that lid at the time. He also made the bent tack rails for my ‘26 along with my floorboards. He is a true craftsman.
Tom Miller
Norman W
First Name: Norman W.
Last Name: Woolley
* REQUIRED* Type and Year of Model Ts owned: 1910 Ford Touring, 1911 Ford Touring
Post by Norman W » Thu Aug 01, 2024 7:13 am
Ludwig Gocek is still around I was on a tour with him this weekend in Conn.
He will be at Hersey this year space c4z 15-20 selling coil box switches,and T parts.I think
his coil box maker is not around.Take him off the RIp list.
Norm Woolley
Woody23
First Name: David
Last Name: Woods
Post by Woody23 » Sat Aug 03, 2024 7:51 am
Hello Colin,
I build and repair early coils I can see if my wood guy would make you a new lid if you like. Shoot me a PM here or I post on Facebook under “williamston T Works”
David Woods
Colin Mavins
First Name: Colin
Last Name: Mavins
Post by Colin Mavins » Mon Aug 05, 2024 9:33 am
Thank you every body I have the solution a member has sold me a lid and is making a second lid for the 1910 box I have so a two for one solution.
Post by Original Smith » Thu Aug 08, 2024 12:12 am
Some of the originals don't fit good if you swap them. Be careful1!
