WTB front wheel ball bearing cups
frank_w
Topic author - Posts: 27
- Last Name: Werle
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring Car
Looking for a usable set of the outer (small) ball bearing cups. I already ordered a set of the larger inner bearing cups from Lang's, but I'd also be happy to buy a complete set if you happen to have one.
- Last Name: Hjortnaes
Re: WTB front wheel ball bearing cups
www.
rockauto.com
rockauto.com
frank_w
- Last Name: Werle
Thanks for the link, but they only seem to carry the Timken roller bearing type. My car still has its original "early" hubs, and I've read on these forums that using roller bearings with those can result in damage to the hub, that's why I'd like to stick with the ball bearings.
- Last Name: Hatch
If you find any they most likely need to be polished. Even the NOS cones need polishing. Good luck with the search. Dan
KeithG
- First Name: Keith
- Last Name: Gumbinger
Hi Frank, I just send you a personal message through this Forum.
Keith
Keith
