FS RACING INTAKE MANIFOLD (SOLD)
Mark Chaffin
Topic author - Posts: 4847
- Last Name: Chaffin
I have two RAJO high volume intake manifolds available for purchase. These were designed for use on a boredout Model T flathead engine block. They are similar in design to the Winfield 2 up 2 down intake manifold. Ports are 1 3/8". Carburetor side throat diameter is 1 5/8". Bolt flange is Winfield Model M201 B size. Price is $200 each plus domestic shipping. Mark Chaffin (951) 805-0928
themadmodelt
- First Name: Brian
- Last Name: Sullivan
- * REQUIRED* Type and Year of Model Ts owned: 1922
Re: FS RACING INTAKE MANIFOLD
VM/txt sent
Mark Chaffin
One sold to Dave. Thank you
Ralph F
- First Name: Ralph
- Last Name: Fitz-Gerald
Mark would this manifold fit a roof liberty eight over head.
Fitz
Fitz
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
Both the single intake and the dual intake port Roof heads have vertical mounting flange holes. No doubt port spacing is near identical tho as the ports are centered about the cylinder pairs
Mark Chaffin
Thank you Kevin for the info.
Ralph F
- First Name: Ralph
Thanks Kevin always good to get good information.
Fitz
Fitz
Mark Chaffin
One remaining. This will be the last for use with a Ford Flathead engine.
blauvelt
- First Name: Douglas
- Last Name: Ogden
Will take the last one.
Mark Chaffin
Sold to Doug. Thank you.
