New 09-10 fan blades
Larry Debaugh
Last Name: Debaugh
* REQUIRED* Type and Year of Model Ts owned: 1910 Tourabout
Post by Larry Debaugh » Thu Aug 22, 2024 10:26 am
Exact 09-10 fan blades die stamped with mounting holes. $140 for a set of 4 , postage $11 US , 09/10 blades have greater pitch than the later blades
, Lang’s will rivet the blades on your hub including the rivets for $30. Larry Debaugh 4103361728
Re: New 09-10 fan blades
Post by Allan » Thu Aug 22, 2024 10:18 pm
Excellent job Larry. They are pressed much more deeply and with greater definition than the later ones. In my experience, they may run a little later, up to 1912, but others may know better.
Larry Debaugh
Last Name: Debaugh
Post by Larry Debaugh » Fri Aug 23, 2024 8:41 am
Thanks Allan, yes I think they were used into at least 11, but I have no documentation, I have several different examples of different definition and angle which I assume changed as Ford changed the coolant system capacity. Larry
Dave_Martin
First Name: David
Last Name: Martin
Post by Dave_Martin » Fri Aug 23, 2024 10:26 am
Larry, Beautiful! Thank you for taking the time to reproduce these correctly.
Larry Debaugh
Last Name: Debaugh
Post by Larry Debaugh » Fri Aug 23, 2024 12:46 pm
Thanks, I was desperate… 3 10’s one blade! Lol
Larry Debaugh
Last Name: Debaugh
Post by Larry Debaugh » Wed Aug 28, 2024 10:15 am
9 sets sold , more still available… Larry
Larry Debaugh
Last Name: Debaugh
Post by Larry Debaugh » Sun Sep 08, 2024 10:50 am
12 sets sold …. Others still available
Stephen_heatherly
First Name: Stephen
Last Name: Heatherly
Post by Stephen_heatherly » Sun Sep 08, 2024 12:00 pm
Will these work on a later fan?
Stephen
Larry Debaugh
Last Name: Debaugh
Post by Larry Debaugh » Sun Sep 08, 2024 3:33 pm
Yes will work through the 20’s and move more air because of the increased pitch, I made them for the 9-11 because they were impossible to find… larry
Larry Debaugh
Last Name: Debaugh
Post by Larry Debaugh » Wed Sep 18, 2024 7:07 pm
Sets still available
Larry Debaugh
Last Name: Debaugh
Post by Larry Debaugh » Wed Aug 20, 2025 10:21 am
I still have fan blades… Larry
Post by Original Smith » Thu Aug 21, 2025 12:36 pm
Great job. It's too bad the current blades were not done correctly! They are so close.
