I made a small run of these rings that go down at the bottom of the rubber horn bulbs just like the original Rubes and Nonpareil had. I used an original ring off of a Rubes bulb for the dimensions. These rings will fit the taxi style bulb which looks a little more similar to the original shape of the Rubes and Nonpareil bulbs.
$35 each plus shipping. I only have a few…
Email me if you want one.
mikebird@lifeattheridge.net
Reproduction rings for rubber bulbs SOLD OUT
Tbird
Topic author - Posts: 1380
- First Name: Mike
- Last Name: Bird
CDooREDW
- First Name: Ron
- Last Name: Wenzel
- * REQUIRED* Type and Year of Model Ts owned: ‘14 SWT Runabout; ‘22 Center Door
Re: Reproduction rings for rubber bulbs FS
Mike,
Sent you an email.
Tnx,
Ron in HSV
Sent you an email.
Tnx,
Ron in HSV
Tbird
- First Name: Mike
- Last Name: Bird
1 sold. Thanks!
Tbird
- First Name: Mike
- Last Name: Bird
Some people have asked about the rubber bulb…
This is where I purchased the bulb from.
[url]https://www.ebay.com/itm/175472959206?i ... 1jVkKm[url]
The rings are made exact to an original that I had and removed off of an original Rubes bulb. The repo bulbs that this guy sells are very close to the overall dimensions of the Rubes bulb so the rings fit perfectly. I have no connection with the seller on EBay
J1MGolden
- Last Name: Golden
I have some new rubber bulbs and some parts for those horns.
The rubber is still pliable, but it may be 10 years ls or more.
Tbird
- First Name: Mike
- Last Name: Bird
More sold, only two left
Tbird
- First Name: Mike
- Last Name: Bird
Re: Reproduction rings for rubber bulbs SOLD OUT
All are sold. Thanks
