(Found)Stewart #22 cast road gear
Post by DanTreace » Sat Aug 24, 2024 3:36 pm
Thanks MTFCA. Got reply and located the part.
The cast version of the early Stewart road gear No. 22, 60T 8P. Has block lettering of Stewart.
Like this one in picture:
Block script #22 road gear 60T 8P.jpg (21.45 KiB) Viewed 808 times
Re: (Found)Stewart #22 cast road gear
Post by Original Smith » Sun Aug 25, 2024 1:39 pm
Good for you Dan. Now, use it! I believe that one is used in late 1912 and 1913. Russ can tell you more.
