I have a brass L-4 Kingston that needs new plates & shafts. The shafts where made from copper tubing & the plates made from body washers.
I see from the parts books that the throttle & choke are the same part #. This throttle plate is 1.060" but the choke plate is 1.125". Are the NH
plates 1.125" ? I don't seem to have a NH in all of my carbs. Thanks guys.
Carb question
Topic author - Posts: 2014
- First Name: craig
- Last Name: leach
Corey Walker
- First Name: Corey
- Last Name: Walker
Re: Carb question
You can use an NH throttle shaft and plate in an L4. Brass one uses the long arms. The choke shaft is larger diameter and the lever part is different, choke plate is larger.
